주요 콘텐츠로 건너뛰기
Google Pixel 5 스마트폰 수리 안내서 및 설명서입니다. 2020년 10월 15일 출시. 모델 번호: GD1YQ, GTT9Q
Why are some functions of my phone not working?
I recently replaced my old phone's battery with a new one and after powering on the device, some functions stopped working such as both rear and front cameras, both speakers, the flashlight, and vibrations and haptics. I tried to calibrate the battery by following the instructions included in the new battery but nothing changed. I changed back to the old battery to see if anything would happen and all of said functions worked again meaning that none of those parts were damaged during the installation process. But switching to the new one causes them to not work anymore. Am I doing something wrong?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi,
If the functions work with your old battery then the new battery may not have enough charge to run them.
Either it needs to be activated to charge properly, or it’s an odd “dud”, or it’s the wrong type or connector on the flex is somehow damaged.
I would check the new battery voltage to see what it’s holding and make sure the connector on the flex isn’t damaged.
Beyond that you may need to wipe the cache and see if it fixes the problem.
Hope this helps
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Diego 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 65
