주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Parts left after assembly
Hi!
I've got two unknown parts after reassembling my iPhone 4S (http://imageshack.us/photo/my-images/705...). Left part is some kind of antenna/ground stuff I suppose, right part is made from rubber material - found it while installing circuit board. Help me to put them into the right place.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 2개
Found where rubber part should be - side of circuit board where QR code label is. One part left...
Thanks, guys!
댓글 달기
답변 3개
선택된 답변
The one extra part appears to be the pressure contact plate of antenna cap, that has screw hole for the top screw of the battery connector.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
The part on the left is a rubber bumper guard that goes alon the top edge of the motherboard to protect the LCD and digitizer cables from rubbing the edge of the board. It is not necessary to reinstall it but it is a good idea to because it is added protection and also takes some play out of the flex cables so they don't giggle around.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I can confirm the part on the left does cover the antenna cap, the one on the right I also have laying around after re-assembly.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dirty Spiv 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 916
