주요 콘텐츠로 건너뛰기
2022년 09월 16일에 발표된 Apple의 "작아진" 플래그십 스마트폰은 6.1인치 ProMotion OLED, 트리플 렌즈 후면 카메라, 5G 이동통신이 특징이며 새로 설계한 "Dynamic Island"를 전면 카메라와 상단 세서 주위에 배치했습니다. iPhone 13 Pro의 후속작.
20 질문 전체 보기
Panic logs- is it the charge port?
Just wondering could someone interprit my panic log.. thanks!
I figure its the Charge Port Flex?
"kernel" : "Darwin Kernel Version 23.6.0: Fri Jul 5 18:05:47 PDT 2024; root:xnu-10063.142.1~1\/RELEASE_ARM64_T8120",
"date" : "2024-10-26 17:56:39.25 +0100",
"panicString" : "panic(cpu 2 caller 0xfffffff030fdb648): SMC PANIC - ASSERTION FAILED: target\/d74\/target.cpp:266: 0,
SMC BSC failure, spreadsheet ver(*10) 150\nS.sensor array 0 - 4 is 0x0, 0x100000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n - Misc(2) OUTBOX1 not ready\nASSERTION FAILED: target\/d74\/target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10) 150\nS.sensor array 0 - 4 is 0x0, 0x100000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n\nRTKit: RTKit-2419.140.12.release - Client: AppleSMCFirmware-4283.140.4.d74.REL\n!UUID: 5cf13dfa-9869-3b7b-a00c-edbeb929a232\nTime: 0x00000001eec26d06\n\nFaulting task 2 Call Stack: 0x000000000004eae4 0x000000000004e488 0x000000000004e2a0 0x00000000000512c4 0x00000000000047e4 0x0000000000020e74 0x0000000000024068 0x000000000003cbf4 000000000000000000\n\nChinook ASC Async error info: \nl2c_err_sts 0x5000fbfc00000000, l2c_err_adr 000000000000000000, l2c_err_inf 000000000000000000\nlsu_err_sts 000000000000000000, fed_err_sts 000000000000000000, mmu_err_sts 000000000000000000\ndpc_err_sts 000000000000000000\n\nMailbox (0): (0)\n Inbox AKF_KIC_INBOX_CTRL = 0x00020001, AKF_KIC_MAILBOX_SET = 0x11111101\n Outbox AKF_AP_OUTBOX_CTRL = 0x00020001, AKF_AP_MAILBOX_SET = 0x00000000\n\n dir endpoint timestamp msg\n ==== ============ ==================
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Nope, according to the best information we have, it's most likely your Power Button Flex Cable. Apple is making it harder and harder for repair shops and customers to interpret their error codes by changing the codes with every new model. We've got a wiki page that lists all the codes we know and their meanings.
iPhone SMC Panic Assertion Failed - iFixit
Here's what it has to say about your phone and the code it's showing.
iPhone Model iPhone 14 Pro and Pro Max
Sensor Array 0x100000
Likely Issue Power Button Flex Cable
I wasn't able to locate any guides or videos specific to that part on your phone, but fortunately Apple has started releasing their repair guides, and iFixit has a copy of the one for your phone right here.
Apple's iPhone 14 Pro Repair Manual - iFixit
Fix an unresponsive power or volume button with this replacement flex cable assembly. 이미지
제품
iPhone 14 Pro Power and Volume Button Cable
$29.99
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Barnes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 8
전체 시간: 63
