주요 콘텐츠로 건너뛰기
eMac은 교육 시장용으로 설계된 올인원 G4-기반 Mac입니다. CRT 화면을 사용하는 마지막 Mac이었으며 학교 및 기타 기관에 저렴한 가격으로 판매되었습니다.
47 질문 전체 보기
Replaced HDD, USB doesn't work.
eMac 1.42
Hey all,
My eMac 1.42GHZ was starting to show its age so I decided to upgrade the hard drive and the optical drive.
The teardown / upgrade went ok - I fix laptops but this was my first eMac. When I turned it on after the upgrade, I reassuringly hear the Apple sound and the screen changes to what you would get when an os isn't installed and I can hear both of the drives, but USB doesn't work.
To be more specific, the ports are getting power (Plugged in a bus powered drive) but the keyboard doesn't work - I try to eject the drive and nothing happens, same when I tried a pram reset.
I've tried:
The keyboard on another system - it works fine.
Multiple USB ports.
External drive in usb ports - the drive powers up fine.
Reseating the IDE & power connectors for the optical drive - I can hear the drive power on so I don't think it’s a power issue.
Different IDE cable.
While I was moving the machine the cover that flips down when the optical drive is ejected broke off. Whilst I would like to fix this at some point, at the moment this is a minor concern.
I'm hoping someone who has done a few of these eMacs has some idea about something that I've forgotten to plug in; I've had a good look inside for things that I might have missed and there’s nothing obvious, but then again things like this are only obvious once you've found them.
Any pointers at all would be great.
Cheers.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Interesting problem. The first thing that comes to mind is an ID conflict. I'm not sure if the drives are on the same bus. Try replacing the hard drive with the old one to help isolate the problem. Also did you reset the RAM or change the RAM: eMac RAM Replacement
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Ben 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 6
전체 시간: 775
