주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
Reuse iMac camera on MacBooks
I have already figured out the pinout of the camera and soldered the wires to a USB connector. It works fine, with one caveat. If I connect it to a MacBook running in clamshell mode, the MacBook would not enable it, since it thinks it's a built-in camera, which of course makes sense.
Now, my question is, is there any way around it? I can think of two possible options:
  1. Change the USB descriptor of the camera, which I doubt is possible. But this would be a universal solution.
  2. Change the behavior on the macOS side not to disable the camera when the lid is closed. I did some preliminary search and didn't find any answers.
So I figured I'd ask this community and see if anyone has a good idea. Thanks.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Sorry I don’t see a way to do that, the camera’s ID is confusing the OS as it was never intended to run two FaceTime cameras at the same time from the same system.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Deling Ren 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 22
전체 시간: 178
