주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz) 또는 2.5 (Turbo Boost 최대 3.7GHz) GHz 쿼드-코어 Intel Core i7 프로세서.
Black sticker/tape on 15" 2014 MacBook Pro Cpu or gpu
I was repairing a 2014 15" MacBook Pro and accidentally removed the black sticker/tape that was surrounding the cpu or gpu, could this cause any problems or can I reassemble the machine as normal? if this could cause a problem could I replace this with something like electrical tape?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Looking at this image can you tell us where you found the black tape
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
it was around the dies on the large chip in the center that has 2 die sections, I assume it was either for heat dissipation or to prevent it shorting on the heat sink.
@jude85858 - Ok, the issue here is this is a thin piece of heat resistant bakelite which is why it crumbled when you lift it off as it’s not very strong. Electricians tape is not what I would use, I would use kapton tape (polyimide tape) likely a few layers as it tends to be thin.
Ok, thank you! I just ordered some.
댓글 달기
답변을 추가하세요
Jude 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 102
