주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple의 2020년 주력 iPhone은 10월 23일에 6.1" OLED 디스플레이, 듀얼 12MP 카메라 시스템, 그리고 다석 가지 색상으로 출시되었습니다. iPhone 11의 후속 제품입니다.
battery replacement gone wrong
so i just finished replacing my battery after watching youtube videos (i'm a beginner) and now my screen dosent show anything, i unplugged the connector for the new battery and connected the old battery and that one didn't turn anything on either.. keep in mind my phone was working fine other than a low battery health, can anyone tell me what this problem could be from?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Its sounds like you have damaged your screen during removal... easily done!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Most commonly an issue such as yours is related to either the connector on the motherboard or at the end of the screen's flex cable. If you're new to those delicate little plugs, it's pretty easy to damage them by pressing too hard or not getting the plug lined up exactly right before pressing the connector in place.
I'd suggest unplugging the display cable then check it carefully on both sides with a magnifying glass and a bright light. You'll be looking for bent or broken pins; bent ones can sometimes be straightened with fine tip tweezers, but missing pins will either mean replacing the connector on the motherboard or getting a new screen.
Assuming the pins all look straight and present, you'll want to clean both sides of the connector with 90% or higher concentration isopropyl (rubbing) alcohol, give it a minute to dry, then carefully reconnect the display. Pay attention to the comment at this point in the battery replacement guide:
Give that a try and let us know what happens.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Tammy Allen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 10
전체 시간: 110
