이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개:
@ahmeduefa connect an external monitor and check to see if that has the same anomaly. If it does not then you have it isolated to your LCD. Double vision like that is usually caused by a bad T-con driver.
oldturkey03 의
Tried another screen and there is no vibration
Is there a solution without changing the screen?
ahmed uefa 의
