iPhone 13 Pro Display is black?
Hey.
I just got my New display. But when i installed it its all Black. but you can here the phone is on? The company that sold it. Says 2 of 1000 it can happend to. Is it fixable on some way?
좋은 질문입니까?
Hey.
좋은 질문입니까?
As I mentioned in the comments, the flashlight test won't help you with your phone, as that only works with LCD based screens, not the OLED display yours uses.
Anyway, outside of possibly bent pins on the connector of the new screen, there wouldn't be anything you could do to fix it. The screen is pretty much an integrated assembly and either works or it doesn't, so at this point it seems pretty definite that you need a replacement.
이 답변이 도움이 되었나요?
yes. i will send it back. So they send me a new one then
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 40
댓글 5개
Try shining a torch into the display. If the backlight isn't working, you should see something when the torch is shone on the display.
bananakat12345 의
@bananakat12345 Sorry, that advice won't help; the iPhone 13 Pro uses an OLED screen where the individual pixels generate their own light, so no backlight is needed on that display.
Jerry Wheeler 의
Markus, have you tried the original display? If it still works the same as it did originally and the new screen doesn't, then it's most likely an issue with the replacement display. Let us know what happens with the old screen.
Jerry Wheeler 의
Might pay to check the ambient light sensor is connected before going for a new display
Chris Stables 의
just tryied with the lamp on the mobile. but the screen is pitch black. not a sign of something but the phone works with the old display that is cracked
markus hoffsten 의
