주요 콘텐츠로 건너뛰기
The 2019 model Razer Blade 15" is a powerful gaming laptop. It features the same variety of ports and design as the previous year's model, but with expanded display options, upgraded graphics, and a 9th gen Intel Processor.
Replacement battery connector not fitting sung.
I had went through all of the steps listed to replace the battery in my wifes Razer Blade 15, and it doesn't want to stay powered on with just the battery. It almost looks as of the connector from the battery is not fitting snug inside. I've made sure that the connector is plugged in correctly, and I have even taken a small piece of electrical tape to try and secure it, but it still will not stay powered on.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
Where did you get this battery from?
댓글 달기
답변 2개
Probably not the correct battery return that one and get one specific for your model
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
It was the correct battery from the ifixit page.
댓글 달기
Hello! Here is the battery that fits your model. (Razer Blade 15" (2018/2019) Laptop Battery)
Please make sure that this is the same battery ordered.
If not it, could be a defective battery. In which case you should request a replacement.
Happy iFixing!
Replace a 5209 mAh battery compatible with your Razer Blade Laptop. 80 Watt Hours (Wh). 15.4 Volts (V). Part #RC30-0270. 이미지
제품
$99.99
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Tony Billegas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 23
전체 시간: 136
