주요 콘텐츠로 건너뛰기
Model A1174과 2 GHz Core Duo 또는 Model A1207과 2.16 또는 2.33 GHz Core 2 Duo
212 질문 전체 보기
질문 마감됨
iMac does not turn ON. See the Green light from Bottom
iMac 2.16hz 20 inch White Not Aluminium.
When i plug in the AC cord and push the power button , nothing happens.
But i noticed a green light from the bottom where the memory is located.
what does that mean.
What i need to do/replace to get the iMac up and running.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The green light may be the ambient light sensor. My advice is for you to set the machine on its back and look. While there, you will be able to see the bottom of the machine and get the last three figures of your serial number for exact machine identification. To diagnose the problem, you'll probably have to remove the frame and look at the diagnostic lights to the right of the RAM slot and let us know what you find.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I've changed your description to what I believe is the correct machine: Apple iMac "Core 2 Duo" 2.16 20-Inch Specs
Identifiers: Late 2006 - MA589LL - iMac5,1 - A1207 - 2118
Here's how to get the frame off:iMac Intel 20" EMC 2105 and 2118 Front Bezel Replacement
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,170
