주요 콘텐츠로 건너뛰기
The tenth generation Corolla (E140/E150) was released in Japan in October 2006. A narrow variant was available in Japan while wider versions were sold internationally.
My horn doesn't sound why is that?
My car was in a flood and we serviced it and it runs pretty well but the horn doesn't work and i don't know why can anyone able to help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
it could be water damage to the wires
댓글 달기
답변 1개
@nazarhakeem check the horn itself first. Just apply some voltage directly from the battery and just touch the connectors on the horn. If the horn now works, you know the issue is with the wiring. Next check the horn relay and see if you have power on that. If so, you need to check your horn button and make sure that it works properly. We will need to know your exact model and year so we can assist you further with the wiring and locations of the components.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Nazar Hakeem 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 13
전체 시간: 25
