주요 콘텐츠로 건너뛰기
The Dodge Nitro is a compact SUV that was produced by Dodge from the 2007 to the 2012 model year.
4 질문 전체 보기
I think my injectors are bad
I think my fuel injectors are bad
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
Did you check for a blown injector fuse? Blown fuel pump fuse? Check all fuses, then if the engine won't start, remove spark plugs and examine them for raw fuel and fuel smell. Try a spark test to verify spark or after putting plugs back onto the engine, spray starting fluid into the throttle body and try starting. Either the engine sputters to life or not. A brief start indicates a fuel system problem. Failure to start from starting fluid can be one of two faults; ignition system fails to generate spark or a faulty crank sensor. A faulty crank sensor will not allow the EFI system to; operate injectors, ignition system for spark and prevent the fuel pump from operating.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Brad Lane 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 7
