주요 콘텐츠로 건너뛰기
Repair information for the HP EliteBook 840 G3. This Hewlett-Packard laptop is designed for enterprise usage.
How to install multiple os in m.2 and sata ssd
There is 2 drive in my laptop 1: m.2 ssd, 2:sata ssd after install multiple os it is showing error and laptop doesn't work
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Typically the boot drives partition table holds the info on where the OS sits. Here you will want to create multiple partitions each one setup to support the given OS. Depending on your OS choices you’ll need to review the docs. As an example with MS-DOS you would run FDISK, with MS Windows 10 run Disk Management Create and format a hard disk partition. You still need a means to jump around the different OS’s. Here’s a helpful guide What is dual boot? With Windows and Linux
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Aum Rajguru 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 114
