주요 콘텐츠로 건너뛰기
2017년 처음 출시된 Nintendo의 최신 하이브리드 콘솔로, 2019년과 2021년에 각각 Lite와 OLED 모델이 출시되었습니다. Switch는 가정용 및 휴대용 콘솔로도 사용할 수 있습니다.
Where to find switch battery connector?
hey,
I was messing with my nintendo switches and wanted to check with multimeter if the battery had any charge left.
But i could not get with the probes into the contacts of the connector, so i tried stripping the cable but that was also a hasle.
So i just pulled the cables out of the white connector..
I tried pushing them back in and several things but i ended up destroying it :'').
Where can i find the white connector things, and what are they called exactly?
Im finding several connectors that look like it but they are 10 times bigger then the one i need.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
i would replace the battery as that doesnt look in great condition with the stripped wires etc
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I know, but i can make the wires shorter and with a new connector its a new battery.
Nobody :(?..
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
i know its not the same but these might work, you would need to swap the connector on the board aswell tho. https://www.aliexpress.com/item/10050059...
댓글 달기
답변을 추가하세요
B100NL 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 38
