주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Craftsman electric start Snow Thrower, model 536.881501, is a device designed to help remove snow from outdoor spaces using its 5 horsepower engine. This page provides detailed information about the product, including repair and maintenance instructions.
Where to spay starter fluidwher
where to spray starter fluid (either) to start thrower
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Starting fluid is best sprayed through the carburetor with the choke open/off through the air intake with the air filter removed (if applicable). If it goes in straight it is best to have the choke open and spray directly into the intake but if this is not possible spraying it in the air box with the air filter removed works more often than not. If either of these are inaccessible you can attempt to remove the spark plug, spray a small amount directly into the cylinder through the spark plug hole and then put it back and try starting it. It only takes a small amount or a quick spray.
If this doesn't start it or if it starts and then immediately dies there may be a fuel issue (especially if it sat unused all season) or another issue to diagnose.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Don Wolters 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 20
전체 시간: 537
