주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for top and front loading Whirlpool brand washers.
Off Balance when spinning
Whirlpool LSQ7030LQ0 washer. Off balance when it spins. I have replace both sets of suspension pads, all 4 suspension springs and checked that the balance ring has fluid in it. What else can it be?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Does it do it if you spin it empty? If not, then it is the clothes distribution.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Yes. It does it empty. I just noticed that it is rubbing the bottom of the tub ring as it spins to the point that it is creating a bur on it.
There is a part, I have never replaced one but I have heard others replace them, under the tub. I can't remember what they called it. Could be a stem, seal and bearing. It isn't an easy replacement but it can be done. That would tilt the tub and cause your symptoms, I suppose.
댓글 달기
답변을 추가하세요
Randall Tipton 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 7
전체 시간: 108
