주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2022년 Apple의 최고급 플래그십. 9월 16일에 출시된 iPhone 14 Pro Max는 6.7형 ProMotion OLED, 새로운 Bionic A16 칩, 트리플 후면 카메라 시스템, 5G 연결성을 자랑합니다. iPhone 13 Pro Max의 후속 제품입니다.
A2894, A2651 mainboard size
A2894, A2651 mainboard size is same? Can I use a2894 mainboard to a2651?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hello Marionet,
Replacing the mainboard of an iPhone 14 Pro Max (A2894) with the mainboard of an iPhone 14 Pro Max (A2651) is technically challenging and may not be feasible due to hardware compatibility issues. Here are the key considerations:
1. Regional Variants and Band Compatibility
  • The A2894 and A2651 are regional variants of the iPhone 14 Pro Max. The main differences often lie in the modem configuration for cellular network bands (e.g., mmWave support in certain regions vs. others).
  • Issue: Replacing the mainboard may result in compatibility issues with your cellular carrier, depending on your region and the bands supported by the new mainboard.
2. Pairing of Components
  • Modern iPhones have tightly integrated components. Critical parts like the TrueDepth camera system, Touch ID (on models that support it), and the battery are paired to the original mainboard at the factory.
  • Issue: After swapping the mainboard, features like Face ID, True Tone display, or even basic phone functionality may not work without reprogramming.
3. Software Lock (IMEI & Activation)
  • Each iPhone mainboard has a unique IMEI and activation profile tied to Apple’s servers.
  • Issue: Swapping mainboards could cause activation problems, rendering the phone unusable unless reprogrammed by Apple or a skilled technician with specialized tools.
4. Physical Fit and Component Placement
  • While both models share the same chassis, there could be subtle differences in the connectors, screw layouts, or component placements.
  • Issue: Mismatched parts may prevent the phone from being reassembled properly.
5. Warranty and Serviceability
  • Any unauthorized hardware modification will void Apple’s warranty and could make the device ineligible for future repairs at Apple-authorized service providers.
Recommendations:
  • Professional Advice: Consult a skilled repair technician experienced with iPhone repairs. They may be able to advise if the swap is possible or feasible.
  • Compatibility Check: Verify the cellular band support and any hardware-specific differences between A2894 and A2651 to ensure compatibility.
  • Alternative Solution: If the mainboard is faulty and you’re looking for a replacement, try sourcing an identical A2894 mainboard instead.
If you decide to proceed, ensure you have the necessary skills, tools, and access to software required for reprogramming components and reactivating the device.
Best,
Christian
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thank you for your detailed explanation.
댓글 달기
답변을 추가하세요
Marionet 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 21
전체 시간: 204
