주요 콘텐츠로 건너뛰기
1.5 Core Solo, 1.66 또는 1.83 Core Duo, 또는 1.83 또는 2 GHz Core 2 Duo 프로세서
My Mac Mini does not respond when connected to a display.
May I ask how to solve the problem of my Mac Mini A1176 having a power on response, but no response when connected to the monitor despite the power light on
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Did you try testing with a second display or double check the display connecting to another system?
While the systems LED may be lit, did you get the startup Bong sound?
This system requires a button battery to hold its settings (PRAM) have you tried replacing it? Mac mini Model A1176 PRAM Battery Replacement
With the cover off do you see any leakage around the electrolytic capacitors on the main logic board?
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thank you, friend. I have tried to replace the motherboard battery and monitor, but there is still no image display. When starting the machine, there is a sound of the optical drive and hard drive starting, but there is no system startup sound as you said. Do you think it is a problem with the motherboard
@uxq7rnbz1tzbxsp - Do you still have the CD/DVD the system came with? One should be marked as a bootable disk see if you can get it to boot.
댓글 달기
답변을 추가하세요
中国缪缪 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 5
전체 시간: 91
