주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2024년 9월 20일에 출시된 iPhone 16 Pro의 수리 안내서, 분해 및 문제해결 정보입니다. 6.3형 ProMotion OLED 디스플레이, Apple의 A18 Pro SoC, 트리플 렌즈 후면 카메라 시스템, 새로운 카메라 제어 버튼이 특징입니다. iPhone 15 Pro의 후속 제품입니다.
iPhone 16pro panic full
Hello, there is a problem with the iPhone 16 Pro turning off and on at regular intervals of about 3 to 5 minutes. The iPhone's screen and back were severely damaged. After resetting the iPhone, I checked the logs with 3utools.
Here is the detailed text from one of these entries. Has anyone seen this? What can I try next?
Thanks in advance for your help,
<"bug_type":"210","timestamp":"2025-01-21 13:03:49.00 +0900","os_version":"iPhone OS 18.2.1 (22C161)","roots_installed":0,"incident_id":"9FD3EC4D-2400-47F8- B79F-4CDF057F1E24")
"build" : "iPhone OS 18.2.1 (22C161)"
"product" : "iPhone17,1"
"socld":"8140"
"socRevision" : "11"
"incident" : "9FD3EC4D-2400-47F8-B79F-4CDF057F1E24" "crashReporterKey" : "b8e714e198a60e73acbb2176b31dcf403cb20f89" "kernel" : "Darwin Kernel Version 24.2.0: Thu Nov 14 22:55:26 PST 2024; root:xnu-11215.62.3~1\/RELEASE_ARM64_T8140",
"date" : "2025-01-21 13:03:49.32 +0900"
"panicString" : "panic(cpu 0 caller 0xfffffff04dabf2d4): SMC PANIC - ASSERT: target\d93Vtarget.cpp:195: 0, SMC BSC failure, spreadsheet ver(*10) 60\ns.sensor array 0 - 7 is 0, 2097152, 0, 0, 0, 0, 0\nF.sensor array 0 - 1 is \n\n - Misc(2) OUTBOX1 not ready\nASSERT: target\d93Vtarget.cpp:195: 0, SMC BSC failure, spreadsheet ver(*10) 60\nS.sensor array 0 - 7 is 0, 2097152, 0, 0, 0 O, 0\nF.sensor array 0 - 1 is 0\n\n\nRTKit: RTKit-2758.60.101.release - Client: AppleSMCFirmware_H17-5204.60.266.d93.REL|n!UUID: 0ab2ea49- c394-3eca-8285-14ef9697a710\nASLR slide: 0x0000000000000000\nTime 0x0000000519a20d15\n\nFaulting task 2 Call Stack: 0x0000000000055688 Ox0000000000055034 Ox0000000000054e50 0x0000000000053804 Ox000000000004176c 0000000000003f4cc 0x0000000000068fac 0x0000000000046af8 0x000000000005112c\n\nChinook ASC Async error info: \nl2c_err_sts 000000000000000000, 12c_err_adr 000000000000000000 12 c_err_inf 000000000000000000\nI su_err_sts 000000000000000000 fed_err_sts 000000000000000000, mmu_err_sts 000000000000000000 \ndpc_err_sts 000000000000000000\n\nMailbox (0): (0)\n Inbox AKF_KIC_INBOX_CTRL = 0x00020001, AKF_KIC_MAILBOX_SET = Ox11111101\n Outbox AKF_AP_OUTBOX_CTRL = 0x00020001 AKF_AP_MAILBOX_SET = 0x0000000O\n\n dir endpoint timestamp msg\n ニニニニニニニ
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
While we do have a wiki page dedicated to the SMC BSC failure, but unfortunately the iPhone 16 is too new; we don't have any data on the error codes assigned to it. Apple is playing dirty by changing the error codes for each new model, so nothing we know about the iPhone 13 to 15 Pro models helps with decoding the 16 or 16 Pro errors.
So at this point all we can do is note the error you've encountered, 0x200000 (or 2097152 as it appears in your panic log), and hope to associate it with a part that successfully fixes the problem. That same code means the front sensor assembly on an iPhone 14 or 14 Plus, but it means a wireless charging coil on the 15 and 15 Plus, so who knows what it means on the 16 Pro?
Alisha (@flannelist), have you heard anything about iPhone 16 updates yet? I checked Jessa's page on iPadRehab but she doesn't have any news on the 16s either.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
@dadibrokeit I have not, but based on the description I might think the wireless charge coil could be to blame, or could also be the front sensor flex with front and back glass damage. But it could also be separation between the boards, if there was a heavy drop. It's hard to say.
Sadly I also haven't found anywhere yet that has these listed. Would that I could just buy a new phone every time they came out purely for the science of it.
의 공유
First of all, thank you very much for your reply. However, I tried replacing various cables and connectors, but could not repair it.
의 공유
@v24fh672lpuheu3 Can you give us a complete list of what you tried? That way we can start trying to gather data on what works and doesn't work when this particular error comes up. As Alisha has stated, it could also be the wireless charging coil, which would require you to replace the entire back of the phone.
의 공유
2097152 is the charging port error code.
3145728 and 2097152 (0x300000 and 0x200000 when translated to HEX) - It's related to the Charging Port Flex per the repair wiki
의 공유
댓글 달기
A bit more information has appeared since this was asked. 2097152 is 0x200000. Repair Wiki's page for the iPhone 16 Pro now groups it with 3145728 (0x300000) and ties both to the charging port assembly and the barometric pressure sensor. Since 0x300000 = 0x100000 + 0x200000, it looks like two separate sensors on the bottom assembly, with 0x200000 being one of them.
I'd be honest about the confidence level: it's low. The two published 16 Pro / 16 Pro Max cases with this value (this thread and one more here) have no confirmed repair, and at least one person reports changing several flexes without success.
Practical order: inspect and reseat the USB-C charging port flex and the bottom microphone / pressure sensor module (corrosion, given the damage you describe), test with a known-good assembly, and only then look at the front sensor flex, the wireless flex and the board.
And as the first answer says, don't carry meanings over from other models: 0x200000 is proximity on the 15 Pro and the wireless coil on the non-Pro 16.
I maintain a sourced table of these codes; this entry is marked as disputed there: https://checkpanicfull.com/iphone/iphone...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
0212 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 8
지난 7일: 43
지난 30일: 169
전체 시간: 7,165
