주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2004년 12월 12일 일본, 2005년 3월 24일 북미, 2005년 9월 1일에 유럽에서 출시되었습니다.
PSP 1001 Right Trigger Unresponsive
Basically I haven't used the PSP in some time and after starting it again I noticed the right trigger is toast, doesn't respond to any clicks.
Anyone know what might fix that?
Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi Alex!
Someone did made a video about how to fix this!
Link: https://youtu.be/edSyysTaAGg?si=0MtDtEgR...
Part:
https://a.aliexpress.com/_EzjnG9i
I repaired many of them and it’s easy! You need to replace the whole flex cable and after this it should be fine.
You need the PSP1000 one. If you have any questions, please let us know!
이 답변이 도움이 되었나요?
점수 1
댓글 8개:
Interesting! I'm a little indimitated at how many parts seem to be in the console but I'll see if I can give that a shot. I'm guessing it's more or less you unscrew the whole thing and simply replace that part you order for it?
Thanks!
의 공유
Hi Alex! Yes that is correct. You need to take the front cover off, then the home button, volume buttons, etc bar, be careful to take it out the connector, all of them are very fragile. And then remove the LCD (it's still connected to the motherboard, so again, be careful). Then take the right board out. Follow this guide: PSP 1000 마더보드 교체 (till step 16) and then put the new part in and reassemble it again. Good luck and be careful!
의 공유
Gonna aim to try that. Thanks Again!
의 공유
My pleasure!! Good luck with the repair!
의 공유
I replaced the cable on my own psp 1000. All the buttons work with the new cable except for the right trigger (the one I was trying to fix). Any ideas an what to do?
의 공유
댓글 3개 더보기
댓글 달기
답변을 추가하세요
Alex Reichmann 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 20
지난 30일: 98
전체 시간: 1,658
