주요 콘텐츠로 건너뛰기
Mazda Motor Corporation/마즈다 자동차의 승용차 및 트럭 수리 안내서 및 지원.
283 질문 전체 보기
Fix the driver's side door interior panel in Mazda Tribute SUV?
The interior driver side door latch no longer works. I suspect the linkage inside the door has broken or come apart. I need to know how to disassemble the door panel to gain access to the door latch mechanism.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
Tom, what year is your tribute?
댓글 달기
답변 2개
선택된 답변
Tom, you forgot to tell us the year of your vehicle. This should work for you "1. Remove the door sail panel. If equipped, disconnect the power mirror electrical connector. LH side shown, RH side similar. 2. Open and remove the door handle finish panel. Pull the door handle outward to fully access the door handle finish panel. 3. 4. 5. 6. Remove the door handle screw. Remove the door inside handle screw. Remove the 3 door trim panel screws. Remove the door trim panel. Pull outward and then upward on the door trim panel. Disconnect the electrical connectors. 7. Remove the door handle from the door trim panel. Disconnect the electrical connector. Press the 2 retaining tabs while pushing the door handle from the door trim panel. Remove the door handle from the door trim panel by pulling it back through the door trim panel. 8. To install, reverse the removal procedure." from [http://Mitchell Repair Information Company,|here]
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
I have a 2004 Mazda Tribute drivers door will not close it won't latch when you shut the door how do you fix this.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
i have the same issue 2001 tribute. I slammed the door close it is shut but now exterior handle is loose and not working, while interior is also not working and the lock button seems jammed
Some issue with the passenger door. Anyone have the schematic for that door?
@rottjocky what make and model vehicle are you inquiring about? What is going on with your door?
댓글 달기
귀하의 답변을 추가하세요
Tom 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 38
전체 시간: 8,032
