주요 콘텐츠로 건너뛰기
2022년 09월 16일에 발표된 Apple의 "작아진" 플래그십 스마트폰은 6.1인치 ProMotion OLED, 트리플 렌즈 후면 카메라, 5G 이동통신이 특징이며 새로 설계한 "Dynamic Island"를 전면 카메라와 상단 세서 주위에 배치했습니다. iPhone 13 Pro의 후속작.
20 질문 전체 보기
”Generic” backglass replacements have weird paint covering the lidar
Hey,
I have recently noticed that back glass replacements come with just black paint over the lidar sensor place, which seems weird.. Could there be any kind of film or vinyl that I could put there between instead?
As you can see, there is no light coming thru.
This is how it looks like from Apple
And phone repair guru just used some kind of plastic film (which he didn’t specify) to put between the carbon back glass and camera bump in his YouTube video:
https://youtu.be/y_zGpx1FRG4?si=owvoDb1c... @ 7:26
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi,
I have been looking for this filter for some time now. I have read several stories of people that replaced their back glass with an aftermarket one and lost LiDAR functionality this way. I found some glass 940 nm (I believe this is the wavelength of the LiDAR modules in iPhones) filters. They block everything around that wavelength including visible light. the ones I found (Aliexpress) could probably fit between the back glass and the sensor. But I'm not convinced this is the best solution. They're made of glass and can't be cut easily to the round lidar hole shape. I'm still looking for a plastic or sticker type alternative. Your best bet in the meantime is probably to use replacement housing from a reputable source. If its from an original iPhone, it'll definitely have the right kind of filter installed.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Elias Lehtinen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 34
