주요 콘텐츠로 건너뛰기
Released in 2004, the Logitech MX510 is an optical gaming mouse. It has a USB cable for connecting to your computer and uses an MX optical sensor on the bottom for tracking movement.
2 질문 전체 보기
Logitech MX510 mouse right button works sporadically
The right button on my Logitech MX510 mouse has stopped working reliably. Sometimes it works with normal pressure, sometimes only with a lot of pressure, and sometimes not at all. Occasionally it will "ghost click" with no pressure at all. Any ideas on how to fix it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 5개
선택된 해법
You might try a brief spray of contact cleaner on the switch. I would first test where it wouldn't show to make sure the cleaner won't damage the finish. Ralph
이 답변이 도움이 되었나요?
점수 2
댓글 달기
가장 유용한 답변
You might need to replace the micro switch. The micro switch can be remplaced by Omron D2F-T.
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
I replaced mine with Omron D2F-T and got a worse clicking experience since the Omron D2F-T is much harder to press than the original micro switch. The original micro switch is called D2FC-F-7N, I'd recommend getting that, I'm changing it also to mine.
I replaced the right switch with one of the extra switches on the left side. There are 5 identical switches and the left ones I never use.
댓글 달기
How old is it?
Try spraying some compressed air between the buttons.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Probably a dodgy connection in there somewhere. Take it apart and look around...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi, I had the same problem with another Logitech mouse. I took apart and I realised, that the button died. I took apart a 10 years old mouse. It contained exactly the same button. I used the dissipative solder sucker and disoldered the buttons out ( I recommand to use midle or right button, because they are not use so often, so you can expect they are in better condition). Be careful! If you don't have any experience with soldering/desoldering, practise with any unuseful parts. If is your new button out, try to measure if is working properly. If so, you can solder it in. Your mouse should be ready to work.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Brian Anderson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 10,386
