주요 콘텐츠로 건너뛰기
Nintendo DSi는 닌텐도 DS 라인의 세 번째 시리즈이며, 2008년 말 일본에서 첫 선을 보였습니다.
DSi blue light flashes and nothing else happens
I have a dsi that the blue light will flash when I press the power button. The top and bottom screen kinda turn a different shade of black for a split second, but nothing else happens. I have tried:
new battery
new daughter board
replaced both screens
cleaned all cable connectors
checked for water damage
soft reset/ hard reset in case of missed update
Replaced the wifi board
I even removed the motherboard and placed it into a known working DSi, but it still had the same issue. The mother DSi is my brother's and has been very well kept. It has no cosmetic or physical damage at all. What would I be looking at as possible reasons it doesn't work?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Owen!
It sounds like you’ve tried everything! So it must be motherboard related. The easiest thing to do, is to replace the motherboard.
You can buy them here:
https://a.aliexpress.com/_EyQsNCY
They are not that expensive anymore, so it’s worth the try!
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I was hoping to fix the motherboard. It has downloaded the games we played. Before I replace the board, I will try to replace the digitizer ribbon cable connector. I heard that may be the issue.
Ahh, I see. Yes, you can try that first. Please also double check all the ribbon cables to see if they are connected properly.
댓글 달기
답변을 추가하세요
Owen Lee Snook 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 17
지난 30일: 75
전체 시간: 310
