주요 콘텐츠로 건너뛰기
How do I open my Sandisk Cruiser?
My Sandisk Cruiser is broken and I'd like to open it up. Please tell me ( or give me a video ) on how to do so.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
It looks like there are a few different versions of the Sandisk Cruzer; it would help a lot of you could add pictures of your stick from several angles and be sure to include one of any visible damage.
기존 질문에 이미지 추가하기
I added images to the question.
댓글 달기
답변 1개
가장 유용한 답변
Mine is a 32GB. It has a top and bottom piece. Look closely at the side edge of yours and you will likely see the joint. They are glued together, so you will have to use a razor (xacto knife) to cut it open. If you do it carefully, you may be able to put it back together.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I’ll try this later this week. Thank you so much!
댓글 달기
답변을 추가하세요
TheMasterG 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 17
전체 시간: 49
