주요 콘텐츠로 건너뛰기
Xbox Series S는 마이크로소프트의 최신 소형 폼 펙터의 디지털 전용 콘솔 게임기입니다. Xbox Series S는 Xbox series X와 함께 2020년 11월 10일에 출시하였습니다.
20 질문 전체 보기
No signal, Hmdi properly soldered
Recently got a broken series x off of ebay recently. The last person who owned it had replaced the hdmi port and done a bad job of it, there were bridged pins and pins that weren't soldered down to their respective pads.
So, I fixed those issues and then reassembled the console to test it but there was still no signal coming from the xbox. The Console would turn on just fine, light, fan spin etc, but no signal.
Here is an image of the pins on the hdmi port:
Sorry for the low quality had to take a picture of the screen on my microscope.
So I guess my main question is what would be the next step in troubleshooting, should I replace the Hdmi retimer?
Thanks for any help.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi there!
1 solder pad looks fused with another one, is this correct? And 1 solder pad has a little damage, is that correct as well? If yes, then please fix those. Otherwise, check the traces and see if they are fine. Otherwise you do need repair them.
If all is 100% OK, then replacing the HDMI IC is the next step!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
LabGrownJake 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 20
전체 시간: 20
