How do I fix stick drift?
Cursor on screen is constantly slowly moving upwards, any solutions to resolve?
좋은 질문입니까?
좋은 질문입니까?
Test it before you open it - plug into a PC, watch the resting value hands-off for 30-60 seconds. Healthy is near 0.00 with a tiny wobble. If it's a steady offset, reset + firmware first, then clean around the base with a damp 90%+ alcohol swab while rotating the stick. If that only holds a day or two, the track is worn - cleaning won't rebuild it, that's a module swap, and check warranty before opening because opening usually voids it.
이 답변이 도움이 되었나요?
My stick drift was caused by wear and tear in the joint of the stick. I replaced the joint and the stick itself and it was back to normal. Costed me only about $11.76
이 답변이 도움이 되었나요?
지난 24시간: 26
지난 7일: 96
지난 30일: 214
전체 시간: 353
Hi! You do need to replace the joystick it self if you are experiencing drift! Which stick is it? Right or left one?
koppie007 의 공유
