주요 콘텐츠로 건너뛰기
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
Touching screen and motherboard connection
Hello I got a 3ds XL from a second handed website and the bottom screen s touch wasn’t working so i opened it to check and i found out that the clip is removed and a little pin is slightly bent I would like to know if it’s fixable. The little clip is also a bit damaged and I tried to put it back but it’s so tiny I can’t put it back. Someone told me that I can use kapton tape but I’m just lost.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi there!
Usually this is lost and you probably won’t get it fixed with any tape. Also the pin is bent, so this won’t be a easy fix.
I would replace the connector for a new one! This should do it. But, you do need soldering experience to get it fixed.
Just solder it out and solder the new one in.
Please let me know if you have any further questions!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
XT-19 pn 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 61
