주요 콘텐츠로 건너뛰기
Unveiled at the 2013 New York and Frankfurt auto shows, the second generation Soul is based on Kia's Track'ster concept.
replace oxygen sensor upstream kia soul 2016 2.0
replace oxygen sensor upstream kia soul 2016 2.0L
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@nick Kia's are right up your alley. You got something to help @josephjose18271 out?
댓글 달기
답변 1개
가장 유용한 답변
The first thing here is to get the car scanned, and NOT buy parts immediately (see the callout I made on this). Given that you know it's the sensor, I will assume you had this done. It's always a P code for emissions, so any basic scanner will do the job here if you decide to buy your own. Anyway, look for a P code related to the emissions for 02 sensors to confirm directly.
If the code returns, it's generally on the exhaust manifold with Hyundai/Kia engines. I found some photos from a 2016 Forte which should match given the engine is shared between Hyundai/Kia and used in multiple cars:
I wish I could find a better photo, but start there. You should be able to reach it yourself, but you may want to lift the car from the bottom and do it that way - the engine bay access is a big problem in the Soul for these parts. Make sure to use a good set of jack stands and put at a minimum, 4 under the car. If you use something like an air jack put good jack stands in place as a safety net.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
joseph joseph 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 238
