주요 콘텐츠로 건너뛰기
The Logitech 502 Lightspeed is a wireless gaming mouse and shares most of the specs with its wired sibling, the G502 Hero. Model number MR0076. Released May 2019.
G502 lightspeed not working except for battery lights
Good evening.
So I got a cheap used G502 under the pretense that the USB was busted and while it would charge, on wired mode it would not work, windows would not recognize it, or even give the little jingle when plugged in... but it would charge.
So I think "ok challenge accepted, it's probably that the data bus on the usb is busted. I solder in a new one and I get a cheap wireless G502 that I've been wanting for years!"
Nope, wireless doesn't work either, G-hub detects the dongle but that's it, It turns on but it doesn't pair with the dongle, it's like the firmware is stuck in some weird infinite loop. The battery indicators are always on and the Logitech logo light is always off. Switching it on and off does almost nothing as well, all it achieves is flickering off the battery indicators for a split second before they turn right back on. If I do it quick enough then maybe the logitech logo light will flicker on for just a nanosecond.
I opened up the device to see if I could figure out what I'm dealing with, here are pictures:
So yeah, and since it's second hand I doubt Logitech is gonna let me RMA this. Any ideas?
As far as I can tell the button daughterboards seem fine btw.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Fixed it by removing this soder:
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
hey, I just had a similar issue, battery indicator lights come on when switched on, but mouse doesnt get detected in windows device manager when plugged in, only the dongle is recognized
I have turned off the "G" LED, so I dont know if thats also flashing like yours.
now I thought after reading your post, that the removing solder didnt actually solve the problem, rather the disconnecting the battery from the board (which you probably did before soldering)
so I tried to only disconnect the battery and it worked again - I think the switch on the bottom of the mouse doesnt really cut the power of the battery, more likely it tells the mouse to stay in standby even if moved around, so disconnecting the battery probably did only reset the mouse and let its uController start again from eeprom
@bere321 Hi do you reckon it would work in a similar manner by letting it uncharge fully?
@alexandrany8473
sorry for answering that late, I think if it works, it will take very long to discarge completely + idk if the battery is good after that (it probably resets at a very very low battery voltage)
댓글 달기
답변을 추가하세요
Omeggga 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 32
지난 30일: 114
전체 시간: 662
