주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2025년에 출시된 Apple의 Mac Studio 데스크탑에 대한 수리 안내서, 분해 정보, 문제해결 정보를 제공합니다. M4 Max 또는 M3 Ultra 칩 모델로 제공됩니다.
Is the SSD replaceable
Is the SSD replaceable like the Mac mini M4?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
Technically these are not true SSD’s, think how the SSD has two parts, the Flash Chips and the microcontroller which manages the data either being written or read from the Flash chips cells, as well as the cleanup. This microcontroller function is within the systems SoC chip, these modules are just Raw Flash (NAND) chips.
You’re in luck! There is a company who makes replacement Flash modules. At this time they only offer the M1 system modules Mac Studio M1 / Ultra Hard Drive Upgrade. I’m sure within the year the 2025 M3/M4 systems will be produced either as a bare board (you need to install the virgin NAND chips) or complete modules. Do keep in mind you’ll also need a second Mac to prep the Flash module/s so you can then install a fresh macOS and then restore your stuff from a backup drive. The original modules can’t be reused as they are locked to your system.
Here’s a bit more Upgrade experiments & Mac Studio Storage Upgrade Success
이 답변이 도움이 되었나요?
점수 4
댓글 달기
답변을 추가하세요
keloide 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 72
지난 30일: 297
전체 시간: 6,637
