功能鍵失靈 Function key malfunction
只有F1~F15失靈,其他按鍵都正常,該怎麼自己修復呢?
Only F1 to F15 are malfunctioning, all other buttons are normal, how to fix it by myself?
좋은 질문입니까?
좋은 질문입니까?
Not sure you can fix this.
Basically, one of the signal lines is severed. Think how the weave of cloth has Warp and Weft here we have one of the Weft lines damaged. You will need to take the keyboard apart quite far to gain access to the connection board to trace out the line that is damaged. This could be corrosion damage or a puncture from some grit under a key pressed into the trace.
The next part gets tricky depending on the damage soldering a wire across the break without out blocking the keys action.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 0
지난 30일: 16
전체 시간: 279
