주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2.2 GHz (Turbo Boost 최대 3.4 GHz) 또는 2.5 GHz (Turbo Boost 최대 3.7 GHz) 쿼드-코어 Intel Core i7 프로세서(6MB 공유 L3 캐시 포함).
Touchpad not found after replacement
Hi all -
Original symptoms were short battery life and touchpad physical clicking not working. I bought a replacement battery and touchpad.
Battery was definitely bulging and putting pressure on the touchpad. I swapped out both and when booted back up - no mouse movement or clicking at all from the touchpad. External mouse works fine, so I went into system preferences and then Touchpad. It said "Touchpad not detected" or something along those lines and had a spinning circle indicating that it was searching for bluetooth touchpads.
So I opened it back up and swapped in the original touchpad - mouse movement but no clicking. But still, system preferences says it doesn't detect a touchpad (I was hoping to at least turn on tap to click.)
So, what am I missing? Is there some extra step to set up the touchpad with the OS? Does the lack of movement on the replacement pad mean that it's DOA?
Thanks for any help!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Did you also replace the trackpad cable with the trackpad MacBook Pro 15" Trackpad Cable (13/14) the cable holds the interface chip which can get damaged.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
Yes, the new trackpad came with a new cable. I haven't removed the cable from either pad, just disconnected from the logic board
의
@agitatedgopher - Try replacing the cable with a fresh one. I’ve hit a few bad ones as I suspect the chip is a bit static sensitive (ESD).
의
Oh, I forgot to come back here, but yes, that fixed it! Went to a mac repair shop, showed them what I needed, the guy in the back who knew everything got me a cable, and I forgot what they charged me for it, but it's working happily now.
의
@agitatedgopher - That's Great! Don't forget to score and accept the answer so others find the solution. Thanks!
의
댓글 달기
가장 유용한 답변
Have a look at the MacBook Pro 15" Retina Display Mid 2014 로직 보드 교체 & check step 25 for the touchpad connection to see if it is correctly seated. This maybe your issue.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Well, that was the first thing I tried, reseating the connector. Still no change. Then I reinstalled the original pad and got mouse movement, but it still doesn't show up in preferences. Then I switched back to the new pad and it's still no movement and not showing up in preferences
의
@agitatedgopher Hmmmm.... Maybe @danj can give some thoughts....
의
댓글 달기
답변을 추가하세요
AgitatedGopher 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 16
전체 시간: 273
