주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PSP 300x는 2008년 10월 15일 미국에서 출시되었습니다. 이 기기를 수리하려면 일반적인 도구만 있으면 됩니다.
Battery Issue - Shutting Off When Bumped
When playing with my PSP 3000 if I bump it or put it down on a hard surface or shake it, the device will turn off. The battery is brand new. I also used a backup battery that is also new and the same think will happen. It was suggested to clean the contacts (isopropyl alcohol to the rescue) and build a foot at the bottom of the battery to make sure the contacts stay in contact with each other. What materials would be good for building the foot out of and are there any other solutions to this issue? Thank you.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
Well, it could be battery related, but what also happens sometimes with the PSP is that some IC falls of from the motherboard… it’s possible that some IC is “loose” and starting to come off. So I recommend to open it up and check if the motherboard is still OK.
Sorry for the bad news, but this thing would be more likely…
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
David 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 46
전체 시간: 366
