Not allowing me to initialize
How to initialize the disk so that I can use it?
좋은 질문입니까?
If your disk won’t initialize, first verify that the SATA and power connections are secure and that the drive is detected in the BIOS.
Then, in Windows Disk Management, right‑click the “Not Initialized” drive and choose to initialize it.
If initialization fails, try using DiskPart from Command Prompt to clean and re-partition the disk.
Also, check for any available firmware or driver updates from WD.
Could you please specify which operating system and system you are using, as the procedures might vary depending on the setup?
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 9
지난 30일: 24
전체 시간: 348
What is the system and OS you are trying to use?
DanJ 의 공유
My PC is Asus i5 4th Gen DDR3 so my HDD drive is showing error in my PC is " HDD is not initialized so how can I fix it??
Mudasir khan 의 공유
