주요 콘텐츠로 건너뛰기
Repair and disassembly information for the Nokia G42 5G Android smartphone, first released in June 2023, built by HMD Global. Identified by model numbers TA-1581 or TA-1591.
Poor reception on Nokia G42
I bought my parents a G42 each at the same time. One of them broke the screen, which I replaced. That same phone is now on the same network as the other and we've noticed that it gets a much worse mobile connection than the other phone (that never had any bits replaced).
For example, the repaired phone only gets Edge but the "untouched" one gets 5G in the same location.
The repaired phone has only recently been changed into the same network as the "untouched" one, so it might well have had a signal issue for a while, possibly ever since I repaired it.
Can anyone advise what the best resolution is? For example, I wonder if the antenna is on the back panel, and perhaps the contacts between this and the main board need cleaning?
Thanks for any help and advice!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
The black and white cables that start from above, flank the battery and reach the bottom are responsible.
I also had problems with the connection and I solved it by DISASSEMBLING everything (except the battery) and REASSEMBLING, paying particular attention to:
  • the cleanliness of the parts
  • the perfect wiring
  • A STRONG TIGHTENING OF THE SCREWS
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
robincm 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 101
