주요 콘텐츠로 건너뛰기
Repair and disassembly guides for camcorders designed by DXG.
Camcorder won't hold a charge
Hey there, in need of some help. I have a DXG-5B6V HD handheld camcorder that won't hold a charge. It was sitting in my mom's garage brand new in the box for years and I finally claimed it.
It takes a 2gb SD card, requires 4 triple A batteries and a cable charge. The SD card is brand new, as are the batteries, and the charging cable isn't damaged.
While it's charging, the screen will occasionally turn on and display a single storage option or a Direct Print option. Selecting the storage option will make the screen go black. It can sit and charge for hours and hours, but when unplugged the screen will turn on for about 30 seconds and then the device will die.
What is wrong with it? Nothing is corroded or damaged. What can I do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @worm2539
What type of batteries are you using in the camcorder?
If using rechargeable batteries then they cannot be recharged by connecting a USB cable to the camcorder's USB port.
They need to be recharged out of the camcorder using an appropriate charger for the type of rechargeable battery i.e. NiMH or Li-Ion.
The USB port is for data transfer only. Here's the user manual if you wish to verify this.
Have you checked that you inserted the batteries correctly, polarity wise?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Worm2539 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 63
