주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
590 질문 전체 보기
Logic Board Replacement Gone Wrong
Howdy. Help, please? Thanks. The short tale: bad spill damage. Corrupted logic board, but only partially. No local video, fried ethernet port. Everything else, including external video, survived. The replacement cost quoted me by the local non-Apple, Mac shop was more than I could justify on a year and 1/2 old machine. I'm handy so off to iFixit I went where a kind gent linked me to an inexpensive ($500) replacement out of Shenzen City. I have it, installed it but get nothing but the chassis power/status light when I boot up. SO, the first question I'm hoping the hive mind can educate me on is: post-logic board swap with everything healthy and in it's proper place, should the computer start up "normally" without any other software/format/etc. procedure? Second, my original board is an i7 2.8GHz model but the replacement is an i7 2.66GHz version. Would this processor change cause an incompatability issue with an already formatted machine? My gut tells me my too good to be true, inexpensive replacement board is DOA from China. Any guidance would be greatly appreciated. Have a great day.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Generally yes replacing a logic board will repair a liquid spill, unless the spill damaged other components like dc in, wireless, hds, optical drives, RAM. If HD was not damaged you should be good to boot the machine... try a safe (shift-) boot just to ensure that there's no unusual startup files hanging you. Try a Single User mode start by holding Command-S during startup. If that doesn't fly you could have other problems.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Trey Follis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 605
