주요 콘텐츠로 건너뛰기
A HD pocket camcorder to compete with Flip mino/ultraHD. Many view the Kodak Zi8 as having a better set and a camera worth considering more then the Flip.
Why does the camera run down in ten minutes?
I charge the camera - with several new batteries - and it runs down within ten minutes. How can I fix the charging mechanism?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
I have tried four new batteries, and two new battery chargers - and also charging it from the computer.
댓글 달기
답변 1개
선택된 해법
Because the battery in your device has aged, if possible, you can replace the camera or buy a battery to replace it
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
@jmartz42667 Fast power consumption solution: Turn off WIFI: WIFI function can be turned off when not in use to reduce power consumption. Adjust backlight and warm light settings: Reducing backlight and warm light can lower power consumption. Waiting for the download and indexing process to complete: After the device completes the download and indexing process, power consumption will return to normal
댓글 달기
답변을 추가하세요
jmartz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 90
