주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
로지텍 MX Master 3S 무선 마우스 수리 및 분해 정보입니다. 2022년에 출시되었으며 모델 번호 MR0077, 부품 번호 910-006557, 910-006558 또는 910-006556으로 식별됩니다. 출시 당시 캐나다에서 판매된 그라파이트 버전의 경우 810- 008296처럼 다른 지역 또는 모델 버전에는 약간 다른 부품 번호가 있습니다.
Both left and right buttons malfunctioning
Less than a year after purchasing the MX Master 3S, the left button started to not register clicks (about 2/3 of the time) and shortly after, the right button followed the same issue.
I would really like to have a guide on replacing switches and the parts that fit here.
Thanks,
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi mate,
This seems to be a very very common issue on these mice. My MX anywhere 3 is doing the same thing with the right click after 4 years where it feels mushy, like something's dislodged.
Because logitech & iFixit have partnered, there are guides on this very website on how to disassemble the mx master 3s, and given the one you want isn't there you can always reference the master 3 guide, since they are very similar.
As for where to find the parts, Logitech isn't selling them here as they likely require resoldering. What you could do however is to open up the mouse, check what the part number is and given you are able to solder, order one yourself & do the repair.
If you don't want to do the repair yourself, there's a chance your local repair shop might do the repair for you since it's a small soldering job. Otherwise i don't reckon Logitech are going to do replacements on that mouse.
Do note, since this is less than a year old, you should be able to claim with logitech given the 1 yr warranty.
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
I just passed the warranty :( lol.
The opening guide currently on iFixit does not include replacing the switches, nor dose it mention parts that would work.
Logitech has replaced the switch from MX 3 to a drastically different type for MX 3S. I placed an order for a couple of Kail Mute 6 x 6 x 7.3 switches, will update if they fits.
Hi Kevin, any luck with those switches? I'm in the same boat as you are.
I’m interested to know too !
Got some kailh gm 8's ( clicky, not silent ) and soldered them on. Just had to cut off the back leg of the switch and for easier shoving back into the hole, ground down the 2 pins. ( the mouse just went out of 2 year warranty couple of days ago. )
댓글 달기
답변을 추가하세요
Kevin Xu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 15
지난 7일: 88
지난 30일: 333
전체 시간: 3,892
