주요 콘텐츠로 건너뛰기
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
Why isn’t my Xbox staying powered on
My Xbox had a broken hdmi port, but turned on fine before I repaired the port. Now that I fixed the port the the Xbox powers on, but then powers back off 5 ish seconds later. I’ve looked everywhere to find a solution but I can’t figure it out. If someone could help me it would be much appreciated. Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Brian!
Most of the time caused by an issue on the motherboard.
Most likely caused by the MOSFET. You can try to replace the power supply, but most likely this is not it.
Fixing the MOSFET is difficult.
Let me know if you need any guides.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Brian McKenzie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 47
