주요 콘텐츠로 건너뛰기
The DualShock 2 Analog Controller first appeared with the PlayStation 2 and featured only minor cosmetic changes in screw locations etc.
left analog stick is becoming increasingly squeaky
Hello,
My Dual Shock 2 is still working well after all these years! However, the left analog stick is becoming increasingly squeaky, and has begun to stick on rare occasion, but still functions near perfectly 99.9% of the time. Is there a simple trick to loosen the stick, and perhaps any buttons such as square and X, to prevent squeaking and sticking, using a household lubricant product such as WD 40?
Thank you,
Daniel McNamara
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Daniel!
First I would try to clean everything in there.
You can just use a wet cloth and clean it (make sure that the cloth is not too wet!).
For the stick, you could use ispropryl alcohol and clean it and see if that makes a difference!
If not, then you might want to replace the stick (worst case).
Please let us know how it goes and good luck!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
D_mac08 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 34
지난 30일: 123
전체 시간: 529
