주요 콘텐츠로 건너뛰기
Nintendo Switch/닌텐도 스위치는 도킹 스테이션을 통해 TV에서 플레이하거나 이동 중에도 플레이할 수 있는 휴대용 게임 콘솔입니다. 2017년 3월 3일 출시되었습니다.
Need help fixing Nintendo Switch fan problem
Hello, like already said in the title I have a problem regarding a friend‘s Nintendo Switch. So, basically the fan wasn‘t working anymore. My friend‘s brother always played Fortnite on it until the fan stopped working and eventually the Switch would always overheat and go into Standby.
I though it would be an easy fix if I would just build in a new fan. Didn‘t work. The battery was also at the end so I also put in a new battery. Capacity was kind of fixed, even though the battery would decharge pretty quick since the heat doesn‘t get blown out.
So I still face the same problem after switching out the fan and the battery. My only theories left are:
1. ⁠onboard problem which I can‘t handle since I don‘t have the equipment to measure voltage etc.
2. ⁠I accidentally broke the lever from the socket of the FFC ribbon cable which connects the fan with the Switch, but only the lever. The pins seem to be fine. But afaik the lever isn‘t needed to actually make the contact with the main board, it just keeps the cable attached, right? In fact I didn‘t broke the lever but I accidentally took it off in flipping it to the wrong side apparently? (Never happened to me before lol) Afterwards, I couldn‘t reattach the lever anymore and since it‘s so small I lost it 😭
So I don‘t know what to do anymore. My friend says it‘s okay if the Switch isn‘t fixable but I just want to be sure that it‘s not because of the broken lever. I hope you guys understand my problem, I had some trouble stating all the facts and explaining the problem. Thanks for all help ^^
Copy-paste from my Reddit post in the ifixit-Subreddit: https://www.reddit.com/r/ifixit/s/o2TtUk...
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi!
Well the lever is required to let the ribbon cable work. Without the lever the cable won’t make (good) contact and thus the fan won’t work.
So, yes the lever is required to be intact to let the fan work.
For now, I would replace that one (this won’t be easy as you need to (micro) solder now.
When this is replaced, it should just work. If not, you need to test some resistors and capacitors on the motherboard.
You can also choose to replace the whole motherboard. Way easier, but way more expensive..
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thank you very much, I‘ll try to replace it ^^
Alright! Good luck :)! If you have any questions, please let me know!
댓글 달기
답변을 추가하세요
χνι 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 51
전체 시간: 237
