주요 콘텐츠로 건너뛰기
2022년 09월 16일에 발표된 Apple의 "작아진" 플래그십 스마트폰은 6.1인치 ProMotion OLED, 트리플 렌즈 후면 카메라, 5G 이동통신이 특징이며 새로 설계한 "Dynamic Island"를 전면 카메라와 상단 세서 주위에 배치했습니다. iPhone 13 Pro의 후속작.
Is it safe to change battery if it got bloated?
My battery has expanded, and it smells. I turned off the phone, but I'm not using it, and it still sticks out. Additionally, the center part of the screen is already curved. Is it safe to still change the battery myself?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
As long as you don't stress the battery in any way when removing it, you should be good
Careful when opening, and before disconnecting he screen, which is tempting, disconnect the battery cable from the board
Then carefully remove the battery using the pull tab adhesive, and if they rip, use a thin syringe to inject isopropyl alchohol underneath the battery, wait 10-15 seconds, then gently push the battery, and if it feels loose enough, take it out, otherwise wait a bit more, still stuck then add more alchohol and make sure it reaches the adhesive to disintergrate it
Long story short, if you are careful and skilled, and you have the patience, then it should be fine. But if you have kids in the house or aren't very confident or good at the skill, it's not recommended
I would go for it, with extreme care - those spicy pillows can burst, after removal make sure it is disposed of safely (I have a puffed up laptop battery, tripled in thickness. Replaced it, and left the old one on my desk, and my 6yr old brother decides to use it as a house for his toy thomas the train to crash into, it ended up in flames)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Jerko Gunjača 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 49
