주요 콘텐츠로 건너뛰기
The DeWalt DWD450 is a corded 1/2" 11 amp right angle drill.
How do I wire up the vsr trigger switch
I have a new switch I need to install on the drill bit don't know how to wire it
A
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
I don't know if wiring diagrams are available for your drill, but generally my process is to open the drill up to get to the switch, then use the existing switch as a guide to where each wire goes. Take one wire at a time and move it from the original switch to the corresponding point on the replacement part. Is there a reason that won't work for you?
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
To much time between new switch arriving. Took old switch out to get part number and. Don’t remember sequence to put back
@tony20811 How many wires go to the switch?
댓글 달기
답변을 추가하세요
Matt Littlejohn 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 18
전체 시간: 74
