주요 콘텐츠로 건너뛰기
Xbox Series S는 마이크로소프트의 최신 소형 폼 펙터의 디지털 전용 콘솔 게임기입니다. Xbox Series S는 Xbox series X와 함께 2020년 11월 10일에 출시하였습니다.
HDMi needs replaced and I have no clue how too
I got my Xbox s last August and it stopped working in December it would turn on and I could hear the Home Screen with headphones in my controller but I can’t get a picture I’ve bought new hdmi cables but it doesn’t fix it would I be better replacing the part myself or taking it for repair?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
So little update I plugged my Xbox in to see if the issue was still ongoing and it was outs of frustration I slapped the top of my Xbox and it started working again I think I might be repair god
댓글 달기
답변 1개
선택된 해법
It depends on how comfortable you are with soldering and disassembly. If you feel like you can do it yourself, go ahead! If not, there are plenty of repair shop that would be happy to fix it for you. If you plan to do it yourself here is the guide and here is the part (Or this part) you will need.
You also might need soldering tools.
If the kit linked is missing something just comment with what it is and i'll add it.
Happy iFixing.
Replace a corroded, dirty, or damaged HDMI port for an Xbox Series S model 1883 14 digit serial number gaming console. 이미지
제품
Microsoft Xbox Series S Model 1883 (14 digit serial number) HDMI Port - Genuine
$17.99
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Thank you for the advice I do have a mini soldiering kit and micro tools but no kidding yesterday I plugged it in to see if the issue was still ongoing it was so I got mad and slapped the top casing on the Xbox and it started working again 😂😂
@kerr35832 Sometimes it just needs motivation. Glad it's working!
Could be a bad joint on the hdmi port connector on the board that needs reflowed and by banging it has knocked it back together. Whilst it's on, gently move the hdmi cable at the port. Don't go mad just tiny movements to see if the picture goes off again. The retimer chip could also be on its was out. Not something you could do at home unless you have a hot air station.
댓글 달기
답변을 추가하세요
Kerr 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 24
지난 7일: 124
지난 30일: 504
전체 시간: 1,396
