What is causing this mac to freeze up after booting? (UNSOLVED)
2014 A1502 here, Clean Installed Big Sur 11.7.10 without issue.
Fresh Thermal Paste & General Internal Inspection under a microscope (No Sign of Liquid Damage) internally it is very clean.
All connections have been re-seated / cleaned / checked and appear OK.
Tested with 2 SSD's both with a clean install of.11.7.10 / SMC / PRAM Reset.
The track pad & Keyboard are working fine during SSD Erase / Format & Clean Install, but at the initial choose country set-up or login window everything just freezes up... The Power button can turn on and shut down without any issue and the keyboard is typing all the keys in terminal (& when using an external display) so the KB & Track Pad appear to be 100% fine. Fan spin is normal and it is not getting hot.. The battery status is unknown (Not swollen) and chargers OK, but the issue happens with or without the battery connected. It has a new track pad cable although the previous owner told me they had already replaced that to no avail. No luck booting into safe mode and apple diagnostics reports no issues found ADP000. I have swapped out the I/O board with another same models part but it made no difference. The LCD Connector on the board is looking clean on the inside & outside. After all of these steps I have found that using an external monitor everything is operating perfectly, KB, TP, WiFi, BT, Camera and so on..... I firmly think the LCD itself is OK as I have also tested using another complete display assembly from a same year and spec model, but it still freezes. Has anyone encountered similar behavior before? Ask Ai ? lol
I have tried with HDMI & a thunderbolt cable connected, with and without an external display connected and switched to mirror display but it is still freezing when I am only using the internal display. The ports are all very clean with no sign of anything unusual inside. I really gave this a thorough look over. Very Weird.
I have tried to install just Windows on it and it installed fine, BUT when I tried to install the 1st set of drivers it restarted as normal and froze again.... Other than that I have tried just about everything I can think of, except running the system without the I/O board connected, but I think that will just make the system run in slow mode and not really prove anything...... Any suggestions?
좋은 질문입니까?
댓글 2개
What does the crash report show you?
DanJ 의
@danj I will add it when it is on the desk again.
livfe 의
