주요 콘텐츠로 건너뛰기
2023년 11월에 출시된 16-인치 맥북 프로의 수리 안내서 및 분해 정보로, M3 Pro 및 M3 Max SoC를 탑재하고 있습니다.
Replace top clamshell, keep existing display?
My Macbook late 2023 16'' MRW33LL/A top half was recently damaged, its all bent but the display works fine. Could I replace the clamshell/mounting hardware and maintain the display? Or is the clamshell/display considered a single piece?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
How did this happen? It looks like the display was forced back somehow.
댓글 달기
답변 1개
선택된 해법
Ouch! The Display assembly is a unitized part. Apple does not offer any of the discrete components. Apple has cracked down on factories funneling parts out the back door bypassing the Apple tax.
Sadly, that only leaves you with replacing the whole assembly. Now the not so fun part, Apple introduced hardware serialization a few years ago which limits what you can replace using removed parts (another Apple Tax!) so you need to get the part directly from Apple or one of their parts distributors if you want to fix your system on your own. Here's the site Self Repair and here's the manual MacBook Pro (16-inch, Nov 2023) and here's the parts breakdown page Orderable Parts, jump down to item 36.
Once you replace the display you will need to calibrate it (updating the systems parts serial number) and align the zone backlight with the display.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Exactly what I needed to know, unfortunate but glad I don’t have to guess about it. Thank you!
Self-repair has gotten a lot more straight forward since the last time I needed to fix a mac. Only about $820 for everything including the hinge covers and tool rental. good stuff.
댓글 달기
답변을 추가하세요
Jk. 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 6
전체 시간: 88
