주요 콘텐츠로 건너뛰기
마이크로소프트의 4K 게임기 Xbox Series X 관련 수리, 분해, 문제해결 정보. Xbox Series X는 2020년 11월 10일에 동반 콘솔 Xbox Series S와 함께 출시되었습니다.
White light and beep for 1 second on switch on
I have an xbox Series X which my daughter took apart and gave me the motherbord to change the HDMI and returned it, she reassembled the console and plugged in the flexi from the Nexus board to to J1 incorrectly, this burnt out the flexi. I have replaced the flexi cable but now when I switch it on I get white light and bleep for 1 second. On investigating I have no V_GFXCORE and the resistance is extreemly low. On injecting 1v at V_GFXCORE nothing gets hot, when I monitor the board with a thermal camera. Not having done one of these before is V_GFXCORE normally such a low resistance almost a short about 0.5ohm.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Hi! Usually it's caused by the MOSFET. Did you checked the MOSFET? It is motherboard related anyway..
댓글 달기
답변 1개
  • Try a UART error reading via a UART USB bridge
  • Check all voltage rails and check caps for shorts
  • hail mary: reball BGA GPU
* Check pwm drivers for the MOSFETs DC-DC boost buck circuits have a PWM signal
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ian Huxstep 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 21
전체 시간: 81
